tried to fix Amana Fridge
acoustic5679
Model is a Amana ARS9169AS side by side fridge.(http://www.homeportfolio.com/catalog/Product.jhtml?prodId=43708) So it stopped cooling in the freezer. I kept hearing a clicking every 1 min and I could tell it was coming from the overload relay. I bought new parts (overload relay and starter relay). Still doing the same thing. I can hear and feel the compressor start, but after about 30 sec, the click happens and it turns off.I am reading the same voltage at the relays at 110. The internal fans that circulate the cold air do not work either. The compressor fan does stay on all the time, unless the defrost mode is triggered. I turned the defrost mode and it seems to be turning and working so I do not think it is this. Any other ideas? or is it time for a new fridge?
  • Replies 28
  • acoustic5679
    10
  • 16345Ed
    8
  • BrewHobbyTech
    5
  • Derik
Check cold control
acoustic5679
as in the dial to make it warmer/cooler in the fridge?  they are all set to coldest
BrewHobbyTech
27 minutes ago, 16345Ed said:
Check cold control
+1 on that. If the compressor actually starts running for at least a couple seconds or more and then shuts down it could be the cold control/thermostat. I had one a couple weeks ago. The control tested okay but it failed under a load. That could be the problem or it could be a bad compressor or something else.
Cold controls should always be set at middle setting.
Turn it all the way off. Does the compressor quit clicking and both fans stop?
acoustic5679
well there is only one compressor fan that is running. The condenser fans do not turn on regardless of where the dials are on the cold controls
There is a condenser fan by the compressor and an evaporator fan in the freezer.
Are you saying the evaporator fan never runs?
acoustic5679
yes sorry. So the condenser fan blows air on the compressor then right?
BrewHobbyTech
Yes, evaporator(fan) is in the freezer section and condenser fan is behind the unit.
Depending on how it is wired, the defrost t-stat may have to close before the evaporator fan kicks on. Looks like the main problem is the compressor is not running or shutting off after about 30 seconds.
Yes, actually across condenser coils.
Check those coils are they clean? You want to get them clean if not.
So does the condenser fan shut off when you close the cold control?
Yes, and he put new start device on it.
Do you think the compressor is seized up?
Let's start with the basics.
Test wall outlet, voltage and polarity okay?
Do you have an ampmeter?
Duplicate post, sorry
Edited by 16345Ed
Duplicate
BrewHobbyTech
As you suggested, check voltage at wall outlet. Turn cold control to off position and you should hear or feel it click off. Then turn it back on and listen for the compressor to start. If it does start and run for a couple seconds or more and then shut down it could be a bad cold control If it doesn't start and you hear a click tripping the overload, then I'd say yeah, most likely a bad compressor. One thing I've been using more often is my cheater 3-in-1 relay. Plug~n~play to test. Once in a while the compressor hangs up. 90% of the time it's a bad compressor but 10% of the time it's not. If the compressor starts and runs with that in place then I'll unplug it and let the pressures equalize and then plug it back in with the old, or a new relay/overload and then take a good listen to how it starts.
acoustic5679
Yes the condenser fan shuts off with the freezer cold control turned to off
acoustic5679
the coils are pretty clean too
acoustic5679
The compressor does get hot on top. Not sure if that's a sign of it teying to work. I keep hearing the clicking though. There is a vibration from the compressor when it clicks. Then 10 or 15 seconds later the compressor stops vibrating upon the next click.
BrewHobbyTech
My best guess with the info you've provided would be either a bad cold control or bad compressor. Try replacing the cold control, if that fixes the problem great, if not it's probably a bad compressor. It's also possible you have a bad capacitor on the start/relay device but I've never had to replace one yet, but there's always a first time.
I'd ohm winding on compressor! You could also do a amp draw of compressor when it is running.  And depending how long it's been going on b4 u arrived, I'd let compressor cool down b4 ruling out start device issues.  But does sound like bad compressor
3-1 hard start devices are used to eliminate start windings from overheating during start up. But... If it's already been clicking on and off for long period of times b4 arrival it's already overheated. Not Ohm readings and amp draw can help confirm issues easily though?
BrewHobbyTech
Bottom line........NO.......it's plug~n~play........hey........I'm a poet and don't know it.......oh nooooooooooooo....
....give me three steps...........
acoustic5679
If it was the cold control that went bad, would the cold start shut off/turn on the condenser fan?  Seems like that part of the cold control is working.
So you put new cold control in and compressor is running and no longer clicking?
When you turn off cold control all cooling stops. You are cutting power to fans and compressor, lights should remain on.
You have a bad compressor.You replaced the overload and relay and the clicking is coming from the overload because compressor will not start and pulling too much amps. It is either lock up or has internal damage.  Also the evaporator fan in the freezer is wired through the defrost thermostat and if the compressor is not working the defrost thermostat contacts will not close so that the reason thats not working.You was right in your first post you need a   NEW     refrigerator.
acoustic5679
Yep I have come to the conclusion I do need a new fridge. Thanks for all the help though. I feel good that I tried.
