Help fixing sabotage or stupidity: GE Profile Bottom drawer fridge (PDS22MBSAWW)
Is there an easy way to unblock a warm air return on a GE Profile bottom drawer fridge?  Can the back external panel be removed to access the warm air return channel ?   Someone has sprayed hardening foam into it from the top left vent that is found in the fridge, blocking all warm air returning from fridge into the freezer.
After spending hours debugging a warm fridge (beer section)/cold freezer, I’ve discovered the problem – a purposely blocked returned air channel.   Both left and right vents in the fridge are blocked.  I can see foam in the left vent.  I've tested by blowing air into the vents (with a leaf blower).  I don’t get any air out of the exit vent that is behind the evaporator in the freezer.
I have no idea why anyone would do this.  It’s either sabotage or stupidity!
The model is:  PDS22MBSAWW.
The GE technical service manual (Page 25) shows various tubes on the back.  I’ve undone the few back screws on the back exterior panel but nothing seems to budge.
Help.  Thanks.
  • rcdr
  • Hiroshi
  • johntech
They make expanding foam solvent it comes in a spray can.
Hi Johntech,
Thanks for the suggestion.  I'll check but I suspect that there are other complications with chemicals.
1.  The walls of the return vent, at least the part I can see within the fridge part, appears to be styrofoam.   So a chemical remover would need to not dissolve that.
2.   The expanding foam cleaners I previously seen are good for uncured foam including cleaning foam guns and nozzles.
I'll check.
Thanks.
Nasty solvents will also make the machine unfit for food use... If it is a straight shot, just drill a new holes, no rules say the return vents have to be fancy little slots or any shape in particular... no foam I know of can resist a drill-bit!
