Replacing interior (oven) bulb on Amana microwave AMV5206BAS
Hello,
I am trying to replace the interior bulb on my Amana AMV5206BAS microwave. The owners manual says to remove 2 screws on the top of the microwave and tip out the trim panel before pulling it up and out. It seems like it is secured somewhere at the bottom of the trim panel at the center. I am afraid I will break it as it is only plastic. Am I missing something else?
Thank you
Dave
  • Replies 4
  • dave42
  • Hiroshi
  • johntech
  • BrewHobbyTech
Quick update....I went to Amana's site. My owners manual was wrong!!! Per their site, I had to remove screws and slide trim panel to the left. It immediately came off. My manual said to remove screws and pull straight up. I would have destroyed the plastic tabs.
Be sure to disconnect the power too, I always do this when changing a microwave bulb as a precaution!
BrewHobbyTech
Quote
And....it would be best if you discharged the hi voltage capacitor after lifting the cabinet off. Most have an internal resistor that discharges them......but don't trust any of them. You're not a happy camper after getting jolted by one of these bastards........it's not a fun time......and it's an event you'll remember the rest of your life.......
I agree it's always a good practice to unplug the unit for changing out a light bulb. Ge has some that they say if you do not unplug the microwave to change the light bulb you will fry the board.
