Hello,
I have a Fisher & Paykel Dish Drawer that is Filling with Water every day and overflowing onto my floor and while we were on vacation into our basement and into buckets.... Model DD603, The repair guy has ordered parts for repair and should be back sometime next week to repair.  At this point I need to know how to shut off the water supply... I have turned off the water supply to the sinks, pulled the power from the dish drawers, yet the drawer keeps filling with water- POS...is making me crazy...
Video located here - http://www.youtube.com/watch?v=Zxvvk0WUsUQ   Dish drawer is refilling from a small water spout behind the little drawer where the dishwasher soap goes while unplugged from power.
  • Replies 4
  • Hiroshi
  • LI-NY Tech
  • NORSTARGURU
  • bmwe92m3fan
you need to find where the water connection is for the dishdrawer ,
if you cant find it i will bet it is behind the dishdrawer
The repairman didn't shut the water off?
Sounds like an off-cycle water valve issue due to sediment or a broken return spring...
Faulty inlet valve. I've changed a few on F&P dishwashers. It's also a common problem for other dishwashers and clothes washers.
  • 4 years later...
bmwe92m3fan
HI - bumping this thread up as I have the same issue -- even after replacing the water inlet valve.   My dishdrawer (DS603) slowly fills up with clean water -- any ideas on what else it could be?
