Manufacturer: Frigidaire
Model Number: FSC23F7DWA
Please and thank you
  • Replies 8
  • MsAnn
    6
Oh man I had a brain fart I forgot about the Frigidaire survival kit Durham gave me months ago.
There is a wiring diagram available and a small tech sheet so let's see how I do with that info.
Sorry brain fart!
Rock on, mah Sistah! :rocker:
Ok I just looked the diagram over and I did not see numbers to tell me what The Performance data  For example thermistors, sensors
The issue is the temps are off I want to determine if it is the ADC, the 2 temps sensors (thermistors) or the defrost t-stat or the main. The diagram is tiny. And it even has a variable speed board Norge compressor. Geez....
Can you provide some information the help guide me in trouble shooting what the problem it is.
I would really appreciate it. If it too much I understand.
Thank you have a lovely day.
From your previous reply, it sounds like you found the service manual for this model. Let me know the PUB number of that manual so I can have a look.
No too much at all! Just that this particular forum is for service manual requests. Please start a new topic on this in the Kitchen forum and we'll whomp up on with you there.
I am soaked sorry I can't look that up right now.
 I think this is it 241532603
That's the tech sheet. Frigidaire, in their infinite wisdom and mercy, has decided to spare us lowly techs the heartache and angst that including the thermistor specs on their tech sheet causes.
Did you find the service manual using Durham's guidelines?
 You're the man! Thank you so much Durham!
