Bought it new on 1-2-15, no extended warranty. It stopped cooling, both fans run, lights, etc work fine. No ice build up,..compressor wont run at all. Checked compressor winding resistance, all 3 checks from pin to pin were 7ohms each. I dont have and cant find the wiring schematic, was trying to verify voltage at "compressor perverter" 120vac is good to connector, without schematic, im unsure where the dc voltage originates, but using my vom, i i had a reading of 2 to 4vdc at the connector to the inverter..not sure why it fluctuated like it did,..however, i was using my Fluke 1520 Megometer, i dont think it reads true rms or fine voltages easily.
Hoping for a bit of insight to say im on the right path and that it is most likely the inverter which failed.
  • Replies 7
  • zmaxhunter
    5
  • northeastappliance
  • Hiroshi
Normal inverter signal voltage is listed as 3-6 VDC, if you have 120VAC and your signal and no compressor start, then it is the inverter.
Part number: WR49X10283
This is the cheapest and most versatile inverter kit!
Sure does sound like a bad inverter. I would also check each pin to one of the copper lines.
Any insight into understanding the service diagnostic functions and is there a certain test which will tell me if its a bad thermister.
With this unit, pressing "water, crushed, cubed" simultaneously enters diagnostics..
Code 00 24 is FF1 thermister test,..not sure what the test result numbers mean, is it an ohms reading? Says 7306
Yet code 00 25 is FF2 thermister test, test result is -- --, perhaps there is no FF2??
I did check each pin to ground, all are clear
For future info to others, I found the Technical Data sheet underneath the plastic cover on top of the unit, remove the 5-1/4" screws and it is tucked in with the wiring
If you are getting 120v a/c on the big plug and 3-6 DC Volts on the small plug you know the main board is gathering the data and telling the inverter to run the compressor.
With each pin being equal ohms and none are shorted, I would say the compressor is ok.
Order it from the link above. If for some odd reason it does not work, you can return it and you are only out the shipping.
If you are really concerned about the thermistor, you can always put it in an ice bath and check resistance. Should be 16.3K ohms.
Sry, i hear you, but im out the shipping and the additional days, weeks, month without a fridge..im looking more for a 100% yes this is bad replace it,..good to go.. thank you both for your help, i do appreciate the replies.
I should highly consider branching out into appliance repair,..there is no one here locally who does it,..closest is about 25m away..
