help! Frigidaire range error code
Somonica
model number: FPCF3091LF
error code: E037
turn on induction/ radiant/ oven, few second later beep with code E037.
Thank you for your help! :)
  • Replies 7
  • Somonica
  • Hiroshi
  • johntech
Error#                          Meaning:                                                         Explanation:        Correction:
37                             Relay Voltage Error                              indicates that the number of relays switched on is wrong                             1) Replace relay board
That is the entry on the tech sheet for this model... I assume they are referring to the "radiant zones relay board."
Part number: 318388400
Thank you for your great help and the quick reply! :)
Is this board hidden under the glass top? do I have to remove the front control first?
Thank!
I got the board today and just installed it.
now it got error code E039, the parts site Q&A said that is a configuration error, but my model do not have the "power" key nor warm key.
Anyone help?
Thank again!
1) Replace relay board.
Execute following sequence to force cooktop recon guration (Be sure the good ESEC20 UIB is installed into the cooktop)
1-Put all rotary control to the rst detent position clockwise (1 o'clock).
2-Put all rotary control to the rst detent position counterclockwise (11 o'clock). The system should then recon gure, showing walking dashes on the cooking zones displays.
3-Put all rotary controls to "Off" position. There should be no more error code and the cooktop is ready for operation.
