Washer will stop at random points. Diagnostic mode did not show error codes. I ran the Automatic Diagnostic Test Mode. Unfortunately, I did it incorrectly, there was laundry in the machine. At the C9 step, there was constant grinding/rattling noise. After this test the machine registered a 4A error code.  I do not see this code anywhere in the tech sheet.
When starting a cycle there is the same grinding/rattling noise.
The suspension rods and springs are rusty but they are intact.
I posted about this machine previously and found out the tub was stuck. we have been using this machine since March with reasonable success.
Any advice/suggestions are appreciated!
  • Replies 1
  • lvasquez11
  • johnlec
