  • Replies 21
  • 16345Ed
    12
  • John in the OC
    10
"Won't spit ice"
I assume you mean dispense ice through door flap.
Is ice chute clear of ice or obstruction?
John in the OC
I took out the Ice dispenser I took out the motor and let it thaw cleaned and wiped down every thing..
Its got the cleanest shoot this side of the Rockies..
When you press the ice dispenser does the auger motor run?
John in the OC
Not anymore....it would clunk clunk stop I would hear it start to turn the auger then clunk clunk clunk...
Now if you watch the vid its just click click click
Give me a few minutes. Checking service manual and wiring diagram.
John in the OC
Hey!
Thank You
Is your ice maker mounted on left side of freezer or way back?
Do you still have motor out?
Do you have a meter for testing?
Motor: Check resistance of terminals where purple and light blue wires were attached. Should be 4 ohms +\- 20%, if not replace motor.
Solenoid: Check resistance of terminals where blue with white stripe and light blue wires were attached. Should be 34 ohms +\- 20%, if extremely high or low replace
John in the OC
in the back with the auger assembly below
Turns out to be inconsequential.
Can you perform tests outlined above?
John in the OC
HOw?
6 minutes ago, John in the OC said:
HOw?
Do you have a multimeter?
John in the OC
Well I was hoping it was just gonna be straight forward with the video.
I don't have that tool
Ok some electrical testing needs done to determine if it's the auger motor, solenoid, dispenser board or power board.
Does water dispenser work?
John in the OC
yep everything works but the auger.....
That would indicate boards are ok.
John in the OC
I just need to inner assembly right I don't have to replace the whole thing do I
Hey
Thanks so much for your help
John in the OC
Balls deep in trying to get the motor out.....
How the heck do you get that auger fork off
Its got a metal band strap around it and the nut
thanks again for your help
  1. Disconnect refrigerator from electrical supply.
  2. Slide Ice Container forward and off of Rail
    Assembly. Remove 2 screws holding Rail Assembly to the two channels fastened to the liner.
  3. Lift up on Rail Assembly and pull forward, freeing it from mounting brackets.
  4. Disconnect Molex connector located at back of Rail Assembly and pull Rail Assembly free.
  5. Remove the rear cover on products with left
    mount ice maker, or the ice maker support on
    models with the rear mounted ice maker.
  6. Remove screw securing green ground wire to
    motor housing on back of Motor Cover.
  7. Disconnect two (2) leads hooked to Auger
    Motor windings.
  8. Rotate Drive Bar and Nut (located on front of
    Motor Cover) in counterclockwise position until it comes free of Auger Motor shaft.
  9. Remove the motor mounting screws ( 3 or 4 depending on motor type) and pull Auger Motor free from Motor Cover.
  10. Replace assembly in reverse order.
