Manufacturer: Frigidaire
Model Number: FFTR1022QW0
Have you validated the model number at an online parts site like Repair Clinic? (yes or no): YES
Going on Service Call this week and Need Tech.Sheet, Icing up in Freezer
RF1405 Frost and Condensation Occurs in Freezer Compartment on Top Mount Refrigerators - search on that, it is already in the downloads section!
Thanks Hiroshi I do know about RF1405. But my problem is the defrost cycle and I need to force it in to defrost mode, that why i am looking for tech. Sheet. I should of been more descriptive.:blush:
This is an R600 unit... it is going to be a chinese knock-off type machine. The tech sheet has almost nothing to it... I see there is a (fuse) in the defrost circuit,  so I would look there immediately. No mention of Forced Defrost mode that i see...
Frigidaire R600- junk.pdf
  • 4 weeks later...
To force a defrost on this unit.  Go to # 2 on the control , Press and hold # 2 for 15 second and defrost will begin. To exit defrost Press and hold #2 for 15 second to return to normal operation.
  • Like 2
