I have noticed that when I try to link files that are in the uploads section, the link works for me, but not for others... Like the Cabrio sheet I recently linked for Ms. Ann.
I started just using the de-formatted link because when I try to link the files with the window that the samurai uses, the graphic is wrong when I return to the site the next day...
https://appliantology.org/files/file/3606-cabrio-tech-sheet-w10026634/
These look perfectly fine to me through my browser right now, but I want to be sure they don't post as gibberish for others viewers of the thread.
Are these linked correctly?
  • Hiroshi
  • 16345Ed
When you paste your link into the message are you using the link (looks like chain link) icon at the top of your message?
You're posting the links correctly, Brother Hiroshi. The message appears to other users because the file hasn't been approved yet so it's not "Live."
I need to approve all uploads so that I can ensure that all the meta tag data is there and correct (so it can be found by search), that the formatting is correct (I have a standard structure I like to use because it makes it easier to scan through a list of search results), and that the PUB isn't already in the Downloads (to avoid duplicate files).
You guys don't need to worry about any of the formatting stuff-- I'll take care of it. If a file PUB isn't already in the Downloads section, please go right ahead and upload it and don't worry about making it pretty. Mucho domos!
