Maytag MFI2569VEQ makes loud buzzy noise
My refrigerator is 8 years old.  I have a service contract and last month they came out and repaired the ice maker.  Since than it has made a loud buzzy/rattling noise.
It is in an enclosure, with about 1/8" of space on either side; though in the middle is tighter.  I found that when I wedged a 0.1" piece of wood between the enclosure and the refrigerator it quiets down considerably.  Does that seem like a reasonable thing to do, or should I call for a repair?  (I can just picture them saying "well, it is making refrigerator noises...")
  • Replies 1
  • Hiroshi
  • Toller
The work they did should still be under warranty, so if it is oppressive and the volume of the noise is annoying you, I would call them to come and check it out... The icemakers of this style have a fan mounted in the back of the compartment they are in, there is a plastic "impinger" piece and a trim plate that could be rattling if they aren't secured...
In your position, I would request they come and finish the job, state that the noise is 100% the result of the repair - as if something is loose after the install.
You shouldn't have to shim anything to have peace in your kitchen!
