hi I watched you YouTube video on checking for no drum movement on this washer, I checked the pressure switch like shown with the aqua wire attached to pin 3 and got 120V so I removed the wire off the pin and retested found 0 V but the wire had 120V. I noticed that you started the washer to fill but when you tested the pin thee washer was not filling, do you have to wait until it is full before the pin will have power?  I am presuming that as I have power on the wire I need a new control board but was also wondering if as there was no power does it point to another problem also. FYI the machine does fill the timer dose go through all the cycles and it drains the drum just moves as if it wants to turn but only moves a little bit.  Thanks in advance.
  • Replies 4
  • 16345Ed
  • attaboye
  • Hiroshi
Does not agitate and does not spin?
did you check belt?
does motor pulley spin?
Is the tech sheet with the machine? it gives specific instructions for testing the motor control...
did you check belt?
both the drum and motor turn by hand belt seems Ok,  if I turn the flywheel the motor pully turns.
could be door lock/latch or motor control board.
