KitchenAid Mod. KGSA906PSS00
Mater need you help to understand my oven. its works well at some moments and at others doesn't.
It always starts well with no problem, along the way trouble starts. when already warm the flame shuts off as it reach's the temp, but when it needs to ignite again the igniters of all the burners go on but not the one of the oven, its like there's a cross over.
The igniter works well at start and some days everything works well and other days the igniter of the oven instead of sparking its the igniters of the burner the ignite making the gas shut off.
I'm not certain if can be the thermometer as when this happens it looks like the temperature stays steady when the oven doesn't ignite, or if its the module that its defected as it sends signal to the burners igniters instead of the oven.
Thanking you in advance
  • Paulo Castro
  • johntech
15 hours ago, johntech said:
The spark board can cause that type of failure. Part number: WPW10331686
