GE Profile Dryer DPVH890JEMV
Customer tells me dryer stopping mid-cycle and have to restart it multiple times to get clothes dry.Check error codes have E12--motor not turning properly or check centrifugal switch. Cleared error code and ran entire test and everything passed. Even ran the inlet thermistor test with heat on and motor ran 15 mind no shutdown. Took apart to visually check for anything untoward. Rotated drum seemed fine, bearing ok, bearing slides ok, vent clear. Restarted in timed dry cycle and it shut off after 6 mind. Restarted immediately ran for 20 secs and would shut down. Waited 20 minutes Restarted and ran for 10 minutes and shut off again.Put back in service mode and inlet thermistor test ran 20 minutes no shut off. What am I missing here.
  • ggeorge227
  • Hiroshi
Sorry DPVH890EJMV
Be sure the door is closing tightly and not allowing the door switch to interrupt the cycle, you may want to wire past it and re-run a test cycle.
Next, I would be observing whether or not the voltage to the motor is being interrupted when the shut-down occurs... if it is steady, I would replace the motor (i don't think you can buy the centrifugal switch separately)
