Accessing potentiometers on Thermador PCG304E/01 rangetop
I have two AP3782975 switches in hand for the x-low burners on a Thermador PCG304E/01 rangetop. I removed the star burners and stainless steel top but can't determine how to get to the switches behind the control knobs. It looks like everything inside is mostly a single piece for both sides/all burners, so would I have to remove the stainless steel front to get to them?
I don't see any way to get to the switches without removing the entire inside assembly unless there's an easier way.  I searched for a service manual or instructions for replacing the potentiometers but haven't found anything to this point.  Would rather correct myself since I have the parts ready to install.
  • Replies 8
  • bivind
  • johntech
  • 16345Ed
Manual is available if you pay subscription fee to this site.
This option is only available for professional servicers, not DIYers. So if @bivind is a DIYer, he is not eligible to purchase a Professional Appliantologist membership.
Oh yeah there is that too, sorry.
Yes you would need to remove the front panel. Sometimes the beauty rings around the knobs have to be removed.  If you go to a parts website like Searsparts or applianceparts pros, pull up that model and you should find an exploded view that may help.
That's the issue - I have searched for a parts diagram many times and can't find one for this model.  No problem with other appliances that I own but the service manual or even diagram doesn't seem to be available.
Website parts.sears.com    Type in model pcg304 and you will see the parts break down. Since you are not a professional repair tech you do not have access to the service manual thru this site. Remove all the knobs ant then remove the chrome trim pieces, the panel should be able to be removed at that point. There may be screws on the bottom of the panel but I don't think there were any on the thermador cooktops I've worked on.
Mine has screws and I don't see how to loosen them.  There is a very small rectangular opening where I can see the screw but not enough opening to get a screwdriver in there.  Even tried a bent one but the opening doesn't allow 90 degrees of access to turn the screw.  Is there some special tool to get in there or another way?  The front screws/rings came out ok but the front won't move - probably due to those bottom screws.
removing the front on this is a night mare...
remove the top to get access to back of valves.
turn off gas and remove flex line feeding rail in front.
remove screws holding rail on bottom.
pull rail back far enough to wiggle the pots off
if you need to set the simmer height turn off power or you will fry the control with the
screwdriver. 120 ac will arc from the pot to the valve.
