HELP..banging whirlpool washer
I have a whirlpool washer, model# LLR6144AQ0, It bangs like crazy when its on the spin cycle. It acts like its out of balance but its not, i have messed with this thing for months and cant make it stop. I did some research and seems the counterbalance spring can cause this, so i took it  apart and the spring is still there, connected and all, nothing wrong. The other shorter springs are all still there and functioning also, so now, i dont know what else to check.. everything ive read points to that counter balance spring and its fine..
  • Chad Ashley
  • abaesemann
  • evaappliance
Washing machine tub suspension pads (package of 3). These pads help to absorb the movement of the washer tub. If a tub pad is worn, the washing machine will be unbalanced and will vibrate or shake during the spin cycle.
Part number: 285744
Part number: 285744
really? it gets pretty vilolent, like its got clothes way un-balanced in it...these will cause all that?
Make sure the self leveling rear legs are not seized up ,check the suspension pads as mentioned earlier , & check the balance ring at the top of the inner tub for leakage.
