Manufacturer: LG
Type of Appliance: Washer
Model Number: WM2140CW
No lights at the panel. Voltage to the main CCU. Do not have a wiring diagram. Service manual available?
  • Replies 6
  • MsAnn
    5
I replaced the hall sensor and the harness. I have to unplug the unit and hold the piwer button 5 seconds the the pause/start button to get it to go into duagnostics and it immediatey goes intobLE error code. I douboe checked the connections at ccu, UI, new harness and the hal sensor. Same thing over and over again.
Edited by MsAnn
Typo
This manual will probably be close enough:
Based on your experience Is more than likley the CCU causing the problem? Btw thank you for the manual.
Great topic for The Laundry Appliance Repair Forum. Start a new topic on this there and I'm sure Brother john63 will have some pearls of wisdom to share with you.
I just got home from work I sure John3 has lot"s of pearls he would like to share. I just wanted a manual and some input. But thanks
Let me try that again. Thank you. I am exhausted and I will definitely check out what John63 has lots to share when I need it. Thank you again.
