I have begun my tear down to do a complete refurb on this stove for my own use.   It's in good shape other than the friggin mouse poop I discovered in the burner box area.   I have to replace the insulation between top of the oven and the burner box as the mice urinated in the corners which have a hole/opening  -  the insulation is ruined.  Nasty....
I've scoured the web and can't get the specific service manual .   The stove is discontinued (Mfgr  date - 1999 ) and I can only find manuals  that are "similar".   I don't know what the "I" stands for in VGIC.  I'm assuming model means "Viking Gas Infrared Convection".   I've seen "VGSC" manuals, but that unit is a "Viking Gas Self Cleaning" .  I know it may be "close enough" but I'd still like to have the exact one if it all possible.
Also
- I did upgrade my membership but that was a while ago..do I have to do that again?
And Can anyone get a hold of HIROSHI for me ?  He responded to my other post - I was hoping for a follow up .
Thank You!
Bob
  • Replies 4
  • SteinkeBeyer
  • Econo Appliance
  • lvasquez11
  • BC3CT
Try this web site allvikingparts.com
  • 8 years later...
SteinkeBeyer
I am also looking for this service manual, VGIC305.
In the event that I cannot be given access to the manual, can anyone tell me if I can access the convection fan from the front of the range?
If I know this it will help me when performing my inspection for a forensic investigation.
In the past, since I am not a repair technician, it is not shared with me.
However I am a forensic engineer. In the past I have worked for and against major appliance manufacturers.
I have pleaded with the website manager to give me access to manuals but they refuse access.
Re
I cannot answer for your model, but the majority of convection fans are accessed from inside the oven. If you look inside the oven, there will likely be Fasteners holding a cover over the convection area. Please let us know how it goes
SteinkeBeyer
Thank you!
