Manufacturer: Whirlpool
Type of Appliance: Washer
Model Number: 110.22994101
Kenmore washer 110.22994101.  IN SEARCH OF MANUAL AND/OR ADVICE
Early symptom: When using cold/warm setting washer stopped filling mid cycle. Customer reported that stop/start (push in-pull out)  timer completed the fill  Had to repeat on/off operation several times to complete cycle. Timer advanced after that. Hot and cold water available.
Current symptom: Only cold water fills. wash cycle will complete.  Warm water not available. Timer stops when using warm settings
Because the timer advanced after physical nudge, I assumed it was the timer. Is this a control board issue or timer issue?
Thank you.
  • Replies 1
  • Ashlander
Tech sheet
For repair help, please start a new topic in the Laundry forum.
Guest
This topic is now closed to further replies.
