Maytag Performa Washer MTW5740TQ0 Reassembled, fill won't shut off
Feeling like an idiot....when I undid the clips to get this thing apart, a little clear piece of tubing came unstuck from under the top.  I can't feel a clip that might hold it or otherwise figure out where it goes,  But with it still loose, the washer fill won't shut off.  Is this the line to a pressure sensor/switch for the fill switch?  Have I missed something else?
  • Replies 7
  • Ladyfire3374
    4
  • abaesemann
  • Hiroshi
Yes that is the pressure tube, they are very short, need to empty tub and blow through it before you reattach.
Thanks.  but where does it go?
Small port on the pressure switch, maybe control board for this one
It's still attached to the switch.  Where does it go on the tub end?  I didn't feel a clip.
There will be an "airdome" on the side of the outer washtub, it will have a nipple for the air tube to attach to
