With our Duet dryer, the power button is often times non-responsive and needs to be pressed several times before it does it's job and lights up the control panel and start button. Any ideas? Perhaps the inter-door lock or control board that the power button interfaces with?
  • Hiroshi
  • leamy
  • taschmitt
The button itself is likely wearing out, I have been known to swap the control lock button with the power button to fix this problem... it requires A+ soldering skills though.
the tact switch on the board is worn out. pull the board take to  tv shop. these switches are common on tv  boards have them repair it for a lot less than new
