wiring thermostat
Nicky
Hi, I just installed a ritetemp programable thermostat. I have a five wire set up and the heat works but the ac and the fan switch don't work. I removed the jumper wire like it  said to and think all the wiring is correct but it looks like something is in the wrong spot. It's a gas fired fired system with the condenser outside. I will call the company but hoping for an answer here. thanks
ok thanks for the input, i figured it out. the jumper needed to stay because i had what was considered a 4 wire system. The blue was an optional power feed to the "c"
Does your thermostat have RH and RC terminals? Are they joined as one?
yes it does have rh rc terminals. that was the problem, i removed the jumper between these because i was reading on wiring a 5 wire system because i was counting the optional blue "c" wire as the 5th wire. it worked out well and works great. thanks
