frigidaire FPCS3085LF hybrid induction stove error code
Hi!
My stove show me an error code F095, what I need to fix again?
Thank!
  • Somonica
  • johntech
Mains voltage signal invalidly phase 1, undervoltage or optocou- pler defective - This is an indication that one phase is wrong. The other phase will still work.
1) Verify AC input voltage at the cooktop input. 2) Verify AC main input cables & screws 3) Verify the fuse resistance to be approximatively 0 ohm. 4) Replace the Induction Generator Housing
try turning breaker off and back on if still not working verify you have 240vac between l1 and l2.
Thank John!
I'll check the voltage and the fuse once I got home tonight. But just in case, do you have the parts number for that board?
Thanks again :)
I do have 240volt beween L1 and L2,。。。
But I cannot find the fuse, anyone can help? Thank!
