Hello - I removed and checked hoses for blockages - dollar coin was removed.
I reassembled everything and still got the "ND" status.
I bought a new pump and replaced - still "ND"
Disconnected the wiring harness to the pump.  Started the spin cycle.  Measured between 12-14V (AC).  What should be traveling through those wires?
What should I try next?
many many thanks.
Peter
  • logcabin
  • abaesemann
What does the pump say on the label for voltage? I would guess a washer pump would need 120v to operate so If no 120v then I would say control is the problem or wiring issue.
Part number: MFS-WF203L-00
120V indeed.  Thanks for your reply.  Much appreciated.
