New Appliance Service Manual added: Viking Compendium of Wiring Diagrams for Various Appliances
View File
  • Miscellaneous: Electric Range Cords / 3-phase wiring---------------- A002 Electrical Connections---------------------------A003 / A004 SparkModules------------------------------------------- A005 Spark Modules 2----------------------------------------- A006 Spark Modules PA020013-042-021------------------- A007 Spark Modules PA020040-041-020------------------- A008 Ignitor Wiring kits 9-28-06------------------------------A009
  • Freestanding Gas Ranges: VGR / VCM Wiring Diagrams--------------------- B001 Wiring Diagrams for Gas Ranges / Ele. Equip. -- B002 VGR 36” / 48” Ranges / Spark Electrode
    (2 Burners)--------------------------------------------- B002 VRT / VRT-R Range Top Wiring Diagram (Non-Re-ignition)------------------------------------- B003 VGRT Range Top with Re-ignition) -------------- B003 Gas 36” / 48” Non-Re-ignition (each Burner) --- B004 Gas 36” / 48” Convection Ranges------------------B005 Gas 36” / 48” / 60” Convection Ranges----------- B006 Gas 30” Non-convection Ranges------------------- B007 Gas 30” Convection Ranges------------------------ B007 VGRC650GQ Pictorial diagram------------------- B008 VGSC Freestanding Gas Self-Clean
    Component Diagrams-------------------------------- B009 VGSC Freestanding Gas Self-Clean (Con’t) ---- B010
  • Dual Fuel Ranges: VDSC30-36 D.F. Ranges with Convection
    (2005 Update) ---------------- C033 VDSC30-36 Dual Fuel 06-1------------------ C033A
    VDSC30-36 Dual Fuel 06-2
    (New Thermostat) ------------ C033B
    VDSC487 D.F. Range with Convection
    (2005 Update) ----------------- C034
    VDSC48 Dual Fuel 06-1---------------------- C034A VDSC48 Dual Fuel 06-2
    (New Thermostat) ------------ C034B VGSC48-6G EOC2 Schematic ------------- C035 VCSC307-367 Dual Fuel 06-1-------------- C036 VDSC367 Dual Fuel 06-2------------------- C037
  • EOC2 Wiring Diagrams: VDSC307 - 4B VDSC367 - 4G VDSC365 - 4Q VDSC367 - 6B VDSC487 - 4G VDSC487 - 4GQ VDSC487 - 4Q VDSC487 - 6Q
  • Electric Ranges: VESC305 Wiring Diagram------------------------------- D001
    VESC305 Wiring Diagram (March 2005) --------------D001A VESC305 30 Inch Electric Range 06-------------------- D001B VESC Pre-Heat 01----------------------------------------- D002 VESC Pre-Heat 02----------------------------------------- D003 VESC Pre-Heat 03----------------------------------------- D004 VESC305 Elements 01------------------------------------ D005 VESC305 Elements 02------------------------------------ D006 VESC305 Surface Wiring Diagram----------------------D007 VESC305 Diagram (March 2005) ----------------------- D008 VESC30&36in Convection Range with Pre-Heat----- D009
  • Range and Cooktops: Wiring Diagram VGSU Gas Cooktops----------------- E001 Wiring Diagram 30” Electric Range top-------------- E001 DECU36---------------------------- E002 DECU45-----------------------------E002 30 Inch Electric Cook top--------------------------------- E003 Dual Element Switches------------------------------------ E004 VECU166 Cook top Wiring Diagram------------------- E005 30 Inch Induction-Radiant Wiring Diagram------------ E006 36 Inch Induction-Radiant Wiring Diagram------------ E007 30 Inch Induction-Radiant Block Diagram------------- E008 36 Inch Induction-Radiant Block Diagram------------- E009 30-36 Mixed Fuel Block Diagram----------------------- E010 EDECU140 A---------------------------------------------- E011 EDECU140 B---------------------------------------------- E012
    EDECU150-160 A---------------------------------------- E013A EDECU150 Cooktop------------------------------------- E013B EDECU150-160 B---------------------------------------- E014 EVECU160 A---------------------------------------------- E015 EVECU160 B----------------------------------------------- E016 VECU166--------------------------------------------------- E017 VESC305 Electric Rangetop----------------------------- E018
    Dual Element Switches------------------------------------ E019 DECU160 Dual Element---------------------------------- E020 Spark Modules---------------------------------------------- E021 VGRT302-362-6B Spark Ignition------------------------E022 VGRT362-4Q Spark Ignition----------------------------- E023 VGRT362-4Q Spark Ignition----------------------------- E024 VGRT480-6G Cord Assembly--------------------------- E025 VGRT 480-6G Wiring Diagram------------------------- E026 VGSU162 Wiring Diagram------------------------------- E027 DECU155 Wire Harness---------------------------------- E028 Surface Burner Component Diagrams------------------- E029-E037 VIRT301 Wiring Schematic------------------------------ E038 VCRT301 Wiring Schematic----------------------------- E039
  • Gas Wall Ovens: WiringDiagramforGas36”W.Oven--------------------------------- F001
    VGSO166 W. Oven------------------------------------------------------- F001 VGDO Wiring Diagram-------------------------------------------------- F002
    Upper Oven Self-Clean Below 650°F ----- F003 Upper Oven Self-Clean Above 650°F. ---- F003 LowerOvenSelf-CleanBelow650°F---- F004 LowerOvenSelf-CleanAbove650°F.--- F004 Upper Oven Timed Bake--------------------- F005 Lower Oven Timed Bake-------------------- F005 Manual Bake – Upper & Lower Ovens---- F006 Manual Broil – Upper & Lower Ovens---- F006
    VGDO 27” Gas Wall Oven---------------------------------------------- F007 Wiring Diagram Built-in Gas 27” W Double
    Wall Oven-------------------------------------- F008 Wiring Diagram Built-in Gas 27” W. Double
    Wall oven-------------------------------------- F009 Designer Double Premiere Oven Schematic--------------------------- F010 Designer Double Premiere Lower Oven Schematic------------------ F011 Designer Double Premiere Upper Oven Schematic------------------- F012 Designer Premiere Double Oven Wiring Diagram-------------------- F013 Designer Premiere Single Oven Wiring Diagram--------------------- F014 Designer Premiere Single Oven Printed Circuit Board--------------- F015 VGSO100 30in W. Oven Wiring Diagram----------------------------- F016 VGSO100 30in W. Oven with Electronic Thermostat---------------- F017
  • Electric Wall Ovens: VEDO 27” Electric Wall Oven------------------- G001 VEDO 27” Gas Wall Oven------------------------ G002 VEDO273 Component Testing-----------G003 / G006 Schematic Wiring Diagram VEDO273 W.
    Wall Oven--------------------------- G007 / G008 VESO105 Wiring Diagram (Schematic) Built-in
    DEDO205-275 Wiring Diagram------------------ G044 DESO175-105 Wiring Diagram------------------- G045 DESO171-101 Wiring Diagram------------------- G046 VEDO277-207-265 Wiring Diagram------------- G047 VESO177-107-165 Wiring Diagram--------------G048 VEIS100 Built-in Smoker Oven Diagram------- G049 DESO-DEDO Install Pre-Heat Boards 1------- - G050 DESO-DEDO Install Pre-Heat Boards 2-------- G051 DESO-DEDO Install Pre-Heat Boards 3-------- G052 DESO-DEDO Install Pre-Heat Boards 4 ------ G053 DESO-DEDO Install Pre-Heat Boards 5 ------- G054 36” Single Wall Oven with Pre-Heat------------ G055 36” Single Wall Oven with Pre-Heat------------G055A 36” Bake/Initial Cycle with Pre--Heat---------- G056 36” Bake after First Cycle with Pre-Heat------- G057 36” Convection/Initial Cycle with Pre-Heat---- G058 36” Convection Bake------------------------------ G059 36” Convection Cook------------------------------ G060 36” Mini-Broil-------------------------------------- G061 36” Maxi-Broil-------------------------------------- G062 36” Convection Broil------------------------------ G063 36” Clean Initiate until Door Lock-------------- G064 36” Clean Door Lock above 575o ± 25o-------- G065 36” Clean Door Lock below 575o ± 25o-------- G066 36” Clean Finish Door below 575o ± 25o------- G067 36” Double Wall Oven with Pre-Heat---------- G068 36” Double Wall Oven with Pre-Heat-3-005—G068A Designer Oven with Analog Clock
    DEDO205-275 --------------- G070 Designer Oven with Analog Clock
    DESO105-201 --------------- G071 Designer Oven with Digital Clock
    DEDO201-271 -------------- G072 Designer Oven with Digital Clock
    DESO101-171 --------------- G073 Digital Clock Components ----------------------- G074 Designer Double Premiere (B&W) Dia. --------G075
    Designer Double Premiere (Color) Dia. -------- G075A Designer Double Premiere Upper PCB Dia. --- G075B Designer Double Premiere Lower PBC Dia---- G075C Built-in Electric Oven Components (4 Pages) G076 Pro-Double Oven-Analog Clock w Digital -- G077 Pro-Single Oven-Analog Clock w Digital---- G078 Professional VEDO277-207-265A------------ G079 Professional VESO177-107-165A------------- G080 VESO Analog Clock with Digital Display---- G081 VEDO Analog Clock with Digital Display---- G082 DESO527-530 Designer Premiere Schematic-- G083 DESO527-530 PCB Diagram---------------------G083A DEDO527-530 Designer Premiere Schematic--G084 Designer Double Select (BK&WH) Schematic-G085 Designer Double Select (Color) Schematic------G085A Designer Double Select (Upper & Lower) PCB-G085B Designer Single Select Schematic----------------G086 Pro Double Premiere Schematic------------------G087 Pro Double Select Schematic--------------------- G088 Pro Double Select Upper PCB Diagram-------- G088A Pro Double Select Lower PCB Diagram-------- G088B ProSingleSelectSchematic--------------------- G089 Pro Single Select PCB Diagram------------------ G089A
    Electric 27” W. Single Wall Oven------ Bake------------------------------------------- Convection Bake---------------------------- Convection Cook---------------------------- Mini-Broil------------------------------------ Maxi-Broil----------------------------------- Convection Broil----------------------------
    Clean Initiate---------------------------------
    Door Lock Below 575° F. -----------------
    Door Lock Above 575° F. ----------------- G012 Clean Finish above 575° F. -------------- G012 Clean Finish below 575° F. --------------- G012 VESO Relay Circuits------------------------------ G013
    VESO Relay Circuits (Update) ------------------- G014 VEDO205 Built-in Electric Double Oven------- G015 Relay Circuits Upper Oven---------- G016
    Relay Circuits Lower Oven &
    8-Position Selector Switch----------------- G017 Relay Circuits Upper Oven (Update) -----G018 Relay Circuits Lower Oven (Update) ---- G019
    Upper Oven Bake-------------------------- G020 VEDO205 Lower Oven Bake--------------G021 Upper Oven Convection Bake------------- G022 Lower Oven Convection Bake------------- G023 Upper Oven Convection Cook-------------G024
    Lower Oven Convection Cook------------ G025 UpperOvenMiniBroil-------------------- G026 Lower Oven Mini Broil-------------------- G027 Upper Oven Maxi Broil-------------------- G028 Lower Oven Maxi Broil-------------------- G029 Upper Oven Convection Broil------------- G030 Lower Oven Convection Broil------------- G031 Upper Oven Clean (Before Door Lock)-- G032 Upper Oven Clean (After Door Lock)---- G033 Lower Oven Clean (Before Door Lock)-- G034
    Lower Oven Clean (After Door Lock) ---------- G035
    Designer Series Electric Wall Ovens
    DESO105 Designer Oven (single) --------G036 DESO105 Designer Time Piece (single)- G037 DEDO200 Designer Oven (double) ------ G038 DEDE200 Designer Time Piece (double) G039
    Designer Double Oven – Time Piece------------- G040 Designer Single Oven – Time Piece-------------- G041 Cooking Module Layout--------------------------- G042 DEDO271-201 Wiring Diagram------------------ G04
  • Warming Drawer and Woks: WiringDiagramBuilt-inWarmingElectricDrawer--------------------------------- H001
    Wiring Diagram Built 24” W. wok (Indoor model only)------------------------------ H002
  • Dishwashers: VUD141 Under counter Dishwasher------ J001 / J002
    VUD140 Under counter Dishwasher-------J003 / J005 VUD040 Under counter Dishwasher--------------J006 DFUD140 Under counter Dishwasher------------J007 DFUD140 Cycle sequence chart------------------ J008 DFUD140 Fault codes------------------------------ J009
  • Compactors and Disposers: VUC Under counter Compactor----------------------- K001 DFC180 Compactor Pictorial Diagram-------------- K002 DFC180 Compactor Wiring Diagram----------------- K003 VBFW 1030 / VBHW 1010 /VCFW 1000 / VCFW1020--------------------- k004
  • Ventilation: VEDV 900------------------------------------------- L005 VIDV 500------------------------------------------- L005 VEDV 1200---------------------------------------- L005 VIPR101 / 161 / 181------------------------------ L006 VIPR Wiring Layout----------------------------- L007 VIPR Down position (OFF) ---------------------- L008 VIPR Up position (# 1) ---------------------------- L009 VIPR Up position (# 2) ---------------------------- L010 VIPR Cable Connector (touch pad to PCB) ---- L011 Designer Series Built-in Hood------------------ L012 VCCI Pro-Hood------------------------------------- L013
  • Refrigeration: VCSB360/420/480 Refrigerator------ M001 Refrigerator Components------------- M002 Wiring Diagrams
    (VCSB360/420/480)------------- M003 The Cooling Cycle
    Line Circuit (#1) Electronic Control Board Energized------------------- M004 Line Circuit (#2) Freezer Thermostat Turned on (satisfied) --------------- M005 Line Circuit (#3) Compressor on- M006 Line Circuit (#4) Compressor at
    Instant Start-------------------------- M007 Line Circuit (#5) Compressor
    During run--------------------------- M008 Line Circuit (#6) Condenser Fan
    Motor Circuit------------------------ M009 Line Circuit (#7) Defrost Running- M010 Line Circuit (#8) Evaporator Fan
    Motor Circuit------------------------- M011 Line Circuit (#9) Freezer Side Panel Heater Circuit------------------------ M012 Line Circuit (#10) Motorized Air
    Door Opening------------------------ M013 Line Circuit (#11) Motorized Air
    Door Closing------------------------- M014 Line Circuit (#12) Defrost Heater- M015 Line Circuit (#13) Defrost Timer
    Motor Running----------------------- M016 Line Circuit (#14) Module Ice
    Maker Circuit------------------------ M017 Line Circuit (#15) Light Circuit-- M018
    VCBB360 Refrigerator / Freezer------ M019 VCBB360 Schematic-------------------- M020 VCBB360 Electronic Function M021 / M024 VUAR-VUWC 24” undercouter refer--- M025 Icemaker In Door Dispenser #1--------- M026 Icemaker In Door Dispenser #2--------- M027 VUAR-VUWC 24” Wine Cooler------- M028 30” AF Wiring Diagram----------------- M029 30” AF Schematic------------------------- M029A 30” AF Light Circuit--------------------- M030 30” AF 120 Volt Circuit----------------- M031 30” AF Sealed System Circuit---------- M032 30” AF Sealed System Circuit (Color)-- M032A 30” AF Icemaker Circuit----------------- M033 36” AF Wiring Diagram----------------- M034 36” AF Schematic------------------------ M034A 36” AF Light Circuit---------------------- M035
    36” AF 120 V olt Circuit------------------ M036 36” AF Sealed System Circuit----------- M037 36” AF Icemaker Circuit------------------ M038 30”AR Wiring Diagram------------------- M039 30” AR 120V & Light Circuits----------- M040 30” AR Sealed System Circuit----------- M041 36” AR Wiring Diagram------------------ M042 36” AR 120V & Light Circuits----------- M043 36” AR Sealed System Circuit---------- M044 VCBB-VFBB-DDBB-DTBB 363G----- M045 VCSB360-420-480 Wiring Diagram---- M046 VCSB481-482 Wiring Diagram---------- M047 VCSB483 SXS Wiring Diagram--------- M048 VCSB-DDSB-DFSB-423G Block Dia-- M049 VCSB-DDSB-DFSB 423G Wiring Dia- M050 VCSB-DDSB-DFSB 483D#
    Wiring Diagram------------------- M051 VCSB-DDSB-DFSB483D# Wiring
    SXS Non-Dispenser Wiring Diagram--- M051A
    Diagram / Dispenser-------------- M052 VCSB-DFSB-DDSB-DTSB 483 SXS
    Block Diagram-------------------- M053 VCSB-DFSB-DDSB-DTSB 483 SXS
    Wiring Diagram------------------- M054 SXS Dispenser Schematic (Rev. 1) ---- M054A SXS Dispenser Schematic (Rev. 2) ---- M054B SXS Wiring Dia. With Disp. (Double
    Water Valve) --------------------- M054C VCSB-DFSB-DDSB-STSB 483G
    SXS Wiring Diagram------------ M055 VUAR-VRBD-VUBD-VUWC
    Refer Wiring Diagram----------- M056 (9-05 Updates)
    36 in. BTM Diagram with Icemaker ---- M057 AF30 Wiring Diagram--------------------- M058 AF36 Wiring Diagram--------------------- M059 AR30 Wiring Diagram-------------------- M060 AR36 Wiring Diagram ------------------- M061 SXS Diagram without Dispenser-------- M062 SXS Diagram with Dispenser------------ M063 SXS Dispenser / Icemaker Circuit------ M064 SXS Dispenser 115 Volt Circuit-------- M065 Dispenser Circuit-------------------------- M066 AF 30” With & Without Adaptor Bd. -- M067 AR 30” With & Without Adaptor Bd. -- M068 AF 36” With & Without Adaptor Bd. -- M069 AR 36” With & Without Adaptor Bd. -- M070 Dispenser Wiring (Child Lock &
    Dual Valve) -------------------------M071
  • Wine Coolers and Ice Machines: VUAR – VUWC 24” WINE COOLER--------------------------- N001 VUIM180 ICE MACHING----------------------------------------- N002 VUIM180 Water Pump (Ice Making Cycle) --------------------- N003 VUIM180 Water Pump (Clean Cycle) ---------------------------- N003 VUIM180 Condenser Fan------------------------------------------- N003 VUIM180 Water Valve Solenoid---------------------------------- N004 VUIM180 Hot Gas V alve------------------------------------------- N004 VUIM180 Compressor (Start) ------------------------------------- N004 VUIM180 Compressor (Run) -------------------------------------- N005 VUIM180 Bin Light------------------------------------------------- N005 VUIM180 Cutter Grid----------------------------------------------- N005 VUIM180 Condensate Pump (Harvest Cycle) ------------------ N006 VCWB300 Wine Cooler Wiring Diagram ----------------------- N007 VCWB300 Wine Cooler Wiring Schematic --------------------- N008 VUWC300 Wine Cooler with Start Capacitor (1) --------------- N009 VUWC300 Wine Cooler with Start Capacitor (2) --------------- N010 VUAR-VRBD-VUBD-VUWC Wiring Diagrams--------------- N011 VUIM1500 Block Diagram------------------------------------------- N012 VUIM1500 Wiring Diagram ----------------------------------------- N013
  • Canadian: VDSC487DualFuelConvectionRangewithPreheat------------------------------------- 13 VDSC30-36 in. Dual Fuel Convection Range with Preheat ------------------------------- 14 VESC30-36 in. Electric Convection Range -------------------------------------------------- 15 VGSC306-4B Self-Clean Gas Convection Range ------------------------------------------- 16 VGSC366-4G Self-Clean Gas Convection Range ------------------------------------------- 17 VGSC366-4Q Self-Clean Gas Convection Range ------------------------------------------- 18 VGSC366-6B Self-Clean Gas Convection Range ------------------------------------------- 19 VGSC486-4G Self-Clean Gas Convection Range ------------------------------------------- 20 VGSC486-4GQ Self-Clean Gas Convection Range ---------------------------------------- 21 VGSC486-6G Self-Clean Gas Convection Range ------------------------------------------ 22 VGSC486-6Q Self-Clean Gas Convection Range ------------------------------------------ 23 VGSC Component legends --------------------------------------------------------------------- 24 VGSC Surface Burner – Element Wiring ---------------------------------------------------- 25
  • Replies 0
