GE Refrigerator Model # GSHL6KGZDCLS
Sweetbrandigirl2004
OK Guys I'm back again with another problem. I just fixed the Auger motor problem with the Help of the very talented John not two months ago and now Houston we have another problem. Now were NOT getting water from the door. The Ice dispenser works fine as do all other settings from the door. Likewise I can hear the click when you press the despenser lever when water is selected, you just don't get any water. Oh I should also note that when you press the despenser lever when water is selected it feel loose like theres NO tension on the lever like it has when ice is selected. SO I need any Ideas on what may be wrong and how to get this panel off. Who will be my repair hero for the day ?
  • Sweetbrandigirl2004
  • Hiroshi
Sweetbrandigirl2004
OK So after posting this I went online to see if anyone else has had this issue and YEs they have One person said they took a hairdryer and heated the turning area from outside and inside the door and began getting water immediately. So I gave it a try and WA LA WATER ! I also one person said that there is a GE has come out with a heater to fix this issue. I'm wondering how hard this is to install anyone got any Idea ? https://www.amazon.com/gp/product/B004H3XWCO/ref=as_li_tf_tl?ie=UTF8&camp=1789&creative=9325&creativeASIN=B004H3XWCO&linkCode=as2&tag=busted-refridge-20
Part number: WR49X10173    It is a pretty easy install, the trick is being sure you space the red splice/clips just right so they clear the plastic frame and allow the display to clip in flush... there is complete instructions with it.
