Manufacturer: WHIRLPOOL
Type of Appliance: DRYER, NG
Model Number: WGD8800YC0
Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Y
Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Y
NEED service manual for whirlpool gas dryer, WGD8800YC0.
specifically, how to open it up for servicing. I see the top is hinged in back to swing up but cannot see how to unlatch it in the front
  • Replies 4
  • Lighthouse
  • asteysn2
  • Hiroshi
Submitted and waiting approval
https://appliantology.org/files/file/3944-whirlpool-wgd8800yc0-dryer-tech-sheet/
Checkout part #43 on the cabinet section of the following link. Also notice part #14 on the top console. I can't remember if it has to be removed also. http://www.searspartsdirect.com/model-number/WGD8800YC0/1198/0151200.html?searchType=modelSearch&q=WGD8800YC0&searchTerm=WGD8800YC0
I didn't find a service manual
Not sure what problem you are having but there is a service bulletin for no heat.
There are spring clips in the front approximately where the lid turns in toward the door, use your putty knife to press one side tab back, ( but don't lift it too far or it will make the other side impossible to release) then poke a flat tip screw driver into the released side seam gap you made to keep it from popping back together, then repeat on the other side's clip... they are spaced symmetrically.
