GE dishwasher / model DU2JV leaves detergent in reservoir, leaks down door, detergent on dishes, doesn't fully dry dishes
Hi all, I have a GE dishwasher model DU2JV that was in our house when we moved it. Recently have been noticing that dishwasher detergent gunk remains in the reservoir, and leaks down the door after we run the dishwasher. The gunk also appears on our dishes that are in front of where the detergent reservoir is. The dishwasher also doesn't dry dishes completely.
Any advice on things I should check? Oddly I can't figure out how to attach images on this site, once I figure that out I can upload what I'm seeing.
  • Replies 4
  • Chat_in_FL
  • Lighthouse
  • CiViCKiDD
Pull the screen out and clean it, check for debris in the sump while you have it out. Make sure your water temp is at least 120 when it enters the DW.
On 4/14/2017 at 5:00 PM, CiViCKiDD said:
model DU2JV
Could you double check that model number? Not finding it.
It pulls up on sears as a Magic Chef.
service matters has a parts list and a use & care guide but no tech sheet
also make sure the water is circulating and being sprayed
Edited by Lighthouse
Water Flow issue:
Got it:
check water level. Clogged fill valve?
  • Chopper screen could be clogged.
