electrolux ewmgd65irr2 rebuilt but tripping breaker, help!
tyler.stabler
Manufacturer: Electrolux
Type of Appliance: Gas Dryer
Model Number: ewmgd65irr2
So I tore apart a gas dryer to fix the issue why the drum would not turn. The problem was a sock lodged into the blower wheel assembly. I put the dryer back together, plugged it in, what do you know it trips the breaker for the outlet. Would this be caused by an unsecured ground wire? Help would be appreciated!
  • tyler.stabler
  • Hiroshi
Dead short from a pinched wire or a wire left disconnected...
Does it trip the breaker instantly upon plug-in? Did you check the door switch wires?
Edited by Hiroshi
tyler.stabler
The breaker is tripped once I press the start button. It does not do anything once I plug in.
Guest
This topic is now closed to further replies.
