Manufacturer: GE
Type of Appliance: Electric range
Model Number: JSP46SP1SS
Trying to find the minimanual for this GE range. Thanks!
  • Replies 7
  • ss120396
    4
  • Hiroshi
Uses this one
Thanks but that's not the right one for my model. This range has convection, warming zone, and glass touch controls, none of which are shown in that mini manual. I looked up the parts diagram and it says I need mini manual 31-14850.
Edited by ss120396
Slide in with Glass Touchpad...
Thanks, but I already have that manual. It helps with replacing parts, and giving general info about that range platform. But it doesn't talk about some of the more model-specific stuff, like how to program the glass touchpad. Especially since the range I'm working on was made almost 10 years after that manual was published. I've leaned the hard way how finicky these electronics can be - once I changed out a surface element on one of these, and got a callback because the customer was having trouble with the oven controls after my repair, even though I didn't work on the boards or anything related to the oven. Luckily I was able to get it resolved without changing any parts, it just took a key dance from the tech sheet. Turns out the mere physical act of moving the control panel to get to the cooktop parts can be enough to throw off the glass controls on these things.
Edited by ss120396
GE site pulls up the minimanual PUB I posted. But here's the minimanual PUB you found:
31-14850.pdf
31-14850.pdf
Thanks so much! This is the correct one for my range.
Good to know!
