maytag washer MHWE250XL00, locks on starts never spin and never unlock unless unplugged and manualy unlocked
simon9991
My maytag MHWE250XL00 , door stay locked as soon as i click start and the motor never runs , had an error f6e1 once , now it only says 88 , ive checked the wire between ccu and mcu , to finaly see that my mcu had a burned spot , the 120volt arrive at mcu and all panel switch are bypassed, will the door lock be also solved if i change the mcu, is it the MCU protecting the machine by keeping the door locked ?
  • Replies 4
  • simon9991
    4
  • 16345Ed
simon9991
My MCU chip had a burnt path , since i had nothing to lose i Tin welded that path to let current pass , tried the ''fixed'' MCU and not working , removed MCU and theres more burnt path now , wondering if the new MCU i ordered will solve things. either the mcu burning itself or something on the washer it making it burn ?  im confused Sorry :(
It will likely fix the problem, you should check the wiring harness from main control to MCU insure continuity on all wires and no shorts.
simon9991
thanks for the answer , its wierd how Maytag retailer here told me its likely not the mcu because they never changed an mcu, they dont have one in hand. and everywhere on the web i see people with bad MCU causing all sort of problems
  • 2 weeks later...
Update : i replaced my MCU , and its still not working , as of now when i sttart the automatic diagnostic test , water fills up , then i get an F6e1 then it drains , and door unlocks . i checked all the wire betweens mcu and mcc..... when i press start to start a normal cycle , the door locks and nothing happens if i press start again the timer flashes even if i power off the washer .... could my MCC be defect too ?  btw my panel switches are both soldered together to bypass them .
