Manufacturer: Bosch
Type of Appliance: Microwave
Model Number: hmb5050/01
Hello sir,
I seek your resources.
Also, it is an combined with a wall oven.
I'm having trouble figuring out how to remove the trim to remove the microwave.
I don't see any screws and i'll bet I'm going to need my hand putty knife.
Any suggestions on that would be fantastic, and i'll further scour the Kitchen Forum
Thank you
Kevin Koontz
ps- I'd like to contribute this service bulletin I just found for Trim Kit install.
https://media3.bsh-group.com/Documents/9000999546_D.pdf
Pg11 makes it appear that the trim just snaps on. I dont see tabs to depress, do I just pull at it?
  • Replies 4
  • ss120396
  • Here Now Tech
  • tfre
With the combo wall oven/microwaves, the trim kit is held in by screws from the back. So you need to pull the whole oven out to get at them. The instructions you linked aren't applicable here, those are for standalone microwaves only.
By the way here is your tech info:
Schematic:
Service manual:
Are you sure you watched the video? I found the above in a few seconds using the search procedure in the video. Also for future reference, better to keep posts in this forum to manual requests only, and then put repair questions in the kitchen/laundry forums.
Edited by ss120396
  • 4 years later...
Yeah, I just replaced a mag in one of these today. The trim is the least PITA part of repairing this microwave. To get the shroud off you need to completely remove the oven and microwave to access the sides and backs to take off several brackets.
  • 2 years later...
Schematic:
Service manual:
Some manuals explain disassembly. It is relevant.
