Gaggenau 450 oven series service manual needed!
Akamai appliance
Manufacturer: Gaggenau
Type of Appliance: Single built in oven
Model Number: Hbb045-6 or b0450610-6
Aloha! I have an error code of "E118". I looked online and it said it was a miscommunication between the display and main board. I replaced both boards and still grave same error code. I then tried operating it again in a bake cycle, and noticed the cooling fan wasn't spinning. I gave it a spin and then started again and it heated perfect and didn't throw that same error code again. I was wondering if anyone had access to this service manual because I want to make sure this is what's wrong. Any suggestions would be greatly appreciated! Mahalo!
  • Replies 4
  • Akamai appliance
  • ss120396
  • jtelepan
Welcome to Appliantology! I think the correct model number is BO450610. There should also be a slash after it with a 2 digit number that denotes the engineering revision, but the first part will probably be enough for locating the service manual. I don't have access to the BSH technical information, but there are others on here who do, so one of them will probably post the manual soon. This section is for getting manuals only, if you need help with the repair once you get the manual you should post in the Kitchen Appliance Repair forum.
Edited by ss120396
Service manual
Akamai appliance
Mahalo Yamabushi and the appliantologly team for your help! I still need the fault code and remedy information if available... I will try post in kitchen forum. Mahalo for the help!!
  • 6 years later...
Any luck ever figuring this out? I have to run this call tomorrow
