Our GE Profile Refrigerator PSS26SGPASS fresh food section temperature is set to the recommended 37°, but actual temperature is 31-32°. I spoke to a service tech who said the small door at the top right of the freezer section, and that opens into the top  left of the fresh food section could be clogged with frost. I can get to and feel inside of this opening in the freezer section, but getting to the opening in the refrigerator section is blocked by panels that I don't know how to remove, and I can't find any video or info on how to disassemble these fridge panels at the top back of the food section. Can anyone show or tell me how to do this?
  • Replies 12
  • chezmich
    7
  • Hiroshi
  • Econo Appliance
  • Debbie M
You have to remove the cover over the lights, which will expose two fasteners, then you have to remove the "cooling tower" that runs up the back wall of the refrigerator section that will expose two more fasteners- after removing all four screws you can take the damper housing off and see if the damper door has broken off of its hinge. If the door flap has broken off, it cannot close, and will cause the fridge to over-cool.
Panels that are not screwed down visibly will most often have tabs that need to be moved one direction, or the other, to release them from the slots that hold them...
Where in the fridge are you keeping the thermometer?
Thanks for helping; I really appreciate it.
It is the fridge thermometer, part of the temp control system. The control has worked well for 13 years (is age a factor here?), but it is set to 37°, the readout actual temp display says 31-32°, and the food is much colder than normal.
I have set a separate thermometer on a center shelf, and it confirms the 31-32° of the fridge display.
A service tech suggested setting the fridge temp up to 40° and see if the temp rises up at least a bit, but this would not be correcting what seems to be an electronic malfunction, because we have not done anything to block or restrict any airflow from the freezer - nothing has changed in our use of the fridge or freezer.
I'd really like to be able to look or feel inside the upper left door or opening from the fridge to the freezer to see if there is any frost blocking the opening, but I don't know how to disassemble those upper back panels in the fresh food section of the refrigerator.
Thanks again!
Thanks, Hiroshi,
Yeah, I see the white thumb screw and the tabs on the lights cover. I'll try it tomorrow.
Really appreciate your help!
Did you find an answer?  I'm about to give up on this fridge.  It's a PSS25SGNASS - about the same age as yours and doing the same thing.  I can't buy produce unless it can stay on the counter because this thing freezes it.  I've replaced the ice maker every year or two and a water valve.  It makes tons of noise, too.  If it's an easy fix, I'll fix it.  But if not, this thing is history.
The problem seems to be that the diffuser door that controls cooling airflow from the top right-hand side of the freezer to the refrigerator or fresh food side has come off its hinges, and that door is behind and part of the long air tunnel on the back wall of the fridge, and either the top section of the tunnel or the entire tunnel has to be replaced - $112 for part + $83 service call + 1/2 hr service to replace ($260+/-??). Being replaced tomorrow. We have already replaced the control board in 2013 - $300 part and service. Service tech feels cost of service is worth the expense. We have had only one other problem with this appliance: cannot use water filter because it clogs after only a couple weeks, our water supply is excellent, GE techs cannot figure why this is happening, so we don't filter our fridge water???
appliances R en
if i were you i would look at replacing this part Part number: WR17X20860
it just may be that your filter head is clogged
good luck
Thanks, great idea - never thought of that, and no service tech ever suggested it??!!
.Thanks, great idea - never thought of that, and no service tech ever suggested it??!!
Debbie M,
The entire diffuser assembly, the large upper section of the air tunnel was replaced. In fact the diffuser door had come off its hinges. The fridge section is now holding at 37-36°, and everything else is working well.
IRONY: Consumer Reports still rates the GE Profile #1 above all other brands, and GE sold its refrigerator division to a Chinese company - go figure!
Not just their refrigerator division - the whole major appliance division!
Consumer reports is a sales rag nowadays-
The diffuser door being stuck open will freeze the filter too... just fill the sink with hot water and let the filter float in it for 20-30 minutes and it will be good to go. If that doesn't have an effect, then go after the filter head
Thanks, Hiroshi!
You have been extremely helpful to us. We had that upper air tunnel assembly replaced - fridge again cooling well, and I'm ordering the water filter head and tube assembly because the water line system clogged up years ago, way before the diffuser door problem happened. It's probably worth the $40+ gamble that that's the issue with the clogging water system...and... the video provided by Budget Appliace Parts to remove and replace the filter head assembly is excellent!!
Thanks again!
Robert
