Front load washer not turning on - How to diagnose?
Press the start button and nothing happens - no lights, no nothing. Prior to this, it was working fine.
This is what i've done so far...
Using a multimeter, i checked...
  1. Socket
  2. Plug fuse
  3. Power at the plug cable connector (which connects to the noise filter)
  4. Power by back-probing the other connector of the wire that goes to the washer at the noise filter (check out picture below).
  5. Random connectors at control board
What else can i do to find out where the problem is?
https://i.imgur.com/wfStUSd.jpg
https://i.imgur.com/ms35t7b.jpg
  • Replies 16
  • Elli
    10
    5
  • sh2sh2
  • 16345Ed
Model number
On 6/14/2017 at 0:56 PM, sh2sh2 said:
Model number
sorry for the late reply. wf0500nce
  • 2 weeks later...
no one? :mellow:
7 hours ago, Elli said:
no one? :mellow:
Still waiting on a valid model number.
Take top off unit. Look for tech sheet follow testing procedures. Since you have and seem to be able to use a multimeter.
Yes and I'd start by verifying a good AC power supply right at the pin connections on the main board.
I have the service manual, but no testing procedure for no power.
You mean at the wire?
At the main PCB: from the main relay, RY3, pin 2 (blue and white wires) to the heater relay, RY5, pin 1 (black wire).
Just tried it. One probe at RY3, pin 2 (blue and white wires) and the other at relay, RY5, pin 1 (black wire). I'm showing 0 voltage. Now what?
Now use the schematic to trace the circuit back and find the missing voltage.
Did i do it correctly though?
Do what? The voltage measurement?
Yes, the voltage measurement.
Also, could i get a little guidance as to how to go about tracing the circuit? I'm not exactly an expert...a fast learner nonetheless. Just a point in the right direction would be aswesome!
