Manufacturer: Maytag
Type of Appliance: Laundry Center
Model Number: MET3800TW1
From images on Sears PD this unit has the controls all up over top of dryer door.
Ive never worked on one before, I'd like to know how to troubleshoot and disassemble.
Ed
  • Replies 6
  • 16345Ed
    4
  • Lighthouse
  • Hiroshi
Tech Sheet in downloads. No Job Aid on Service Matters.
I think I worked on one of these (old age memory sucks) and it wasn't too bad. Easier than the GE laundry center.
Edited by Lighthouse
add info
Thanks! yeah found that one figured it may be close enough but since I don't know how to take it apart thought I may as well as for TS with the Job Aid.
No better way to make a new customer nervous then fumbling trying to take their unit apart. ☹️
Edited by 16345Ed
That is the TS that came up for it on service matters.
Maybe they will be one of those that leaves you alone.
I'll figure it out. Always do. ??
It's not very different than the units with the control below dryer.
Three screws hold face place that covers area between washer and dryer. Then washer comes apart like normal with the big spring clips. And washer tub frame on same slides as other laundry centers.
Control panel has screws on top to remove it then you can remove dryer front.
Edited by 16345Ed
good 'ol direct drive in Maytag duds
