This washer periodically gets a te control error. I checked the harness connections which are solid. Is this a possible problem with the main pwb or the display pub?Or what else could I check related to this issue? Thanks!
  • herfdog
  • john63
  • Richard Demint
Richard Demint
an intermittent error code? sounds like you have a loose something, did you physically unplug every plug, look at both sides for corrosion and then plug back in?
Add Ox Gard or Dielectric Grease to the plug...at the Thermistor...located at the front/bottom of the tub.
Done. No further intermittent "tE" errors.
  • 4 weeks later...
Thanks for all the great advice. Unfortunately, I did check, unplug/plug connectors several times and added dielectric grease to connection at thermistor with no change. Any other ideas?
