Samsung RF28HDEDBSR 23E Condensor Fan Error
26 minutes ago, Vance R said:
Just curious, have you tried the force mode step 1? It turns on all fan motor and force the compressor to run at 100%.
No I didn’t.  Why didn’t I think of that 😬. Thanks. Kicking my own ass.  I should have known that.  Thanks!
  • 1 month later...
Ok just had the same issues. What we did to correct it was rewire the cond fan motor. While speaking to tech line they told us unit was unrepairable. Ref was only 2 years old. We ran wires from the board directly to the fan and customer now has a working ref
  • 7 months later...
On 12/20/2019 at 12:09 PM, David Jero said:
What ever happened here.  I have the same problem today.  This is the second Samsung refrigerator giving me the same problem.  I followed all the same steps here.
Hello, I am having the same problem with the evaporator fan motor, 2-3vdc. Did you figure out what the problem was?  Also, is there a way to check the evaporator fan motor, and how do I replace the "main pcb ground?
rf26hfen
  • 1 month later...
I had this problem on a fridge I was working on. Before the error btw I had repaired a bad inverter board and main control board. So on its test run after compressor and whole fridge had been warm for over a week the fridge shows this error. It says condenser fan so I go back and see it is off. I have it a flick and it kicked on. This is not the first time this has fixed the issue with fan being off. Sometimes dust can catch it or it just needs a "jump". Hopefully for someone this helps.
