Icemaker not producing anything - where to start?
  • Replies 7
  • jmm
    4
  • Chat_in_FL
  • Hiroshi
  • Lighthouse
Check that the temperature in the freezer is around 0 degrees fahrenheit first. From there check the icemaker, the water valve, and the tubing for ice blockage.
What ever happened with this:
This might have something to do with it.
Sorry - I dont have permission to view what you posted - can you send by another means?
The temp is good, water pressure to the door spigot hasnt changed, and tubing doesnt have any blockage that I can see. I'm not sure what steps I need to take to check out the icemaker unit itself - does anyone know of a YouTube?
Check the toe grill at the bottom front of refrigerator. Should be a tech sheet on the icemaker, including test points, there unless someone has removed it,
Watch video on link for the part
Part number: AP2984633
Thanks - looks pretty easy.
