Manufacturer: Kenmore
Model Number: 111.73022710
This is probably a long shot.
This is one of the new Kenmore Daewoo refrigerators. Sears still does not have it on searspartsdirect.com
Customer just bought it Friday is so far is not too happy with it.
Looking for any information so I can help him some.
My guess is that these are going to be hard to get information on. If not able to get information for these then I guess I won't be servicing them.
I think you're right. I can't find anything on this one. And accessibility of service literature is a key prerequisite for successful service calls.
This may be a long shot, but I know the Bosch full depth french door fridges are made by Daewoo as well. Maybe the manuals for those could help?
Good info, Brother @ss120396
@Lighthouse find a model number for a Bosch that looks similar to this one and I'll get the manual for you.
  • Thanks 1
B22CS50SN Bosch "Linea." I see mention that this is made by Daewoo- The Bosch Quickfider shows it as the X-Cool Side by Side.
pub # 58300000186266     ...so check this manual out and see if it matches your machine??
This Kenmore is a french door, not side by side. Also from what I've seen, the Bosch side by sides are their own design from China, not Daewoo.
Found records of shipments from Daewoo of South Korea containing Bosch fridges: https://panjiva.com/Manufacturers-Of/bosch+refrigerators
Try "B26FT70SNS"
Ok, thank you ss... here is the manual for that model number.
  • Thanks 1
Thanks everyone. I will have to check it all out when I get back to the real world. I am taking a little time R&R
  • 2 years later...
Had a ff fan stop working with this mdl 111.73045610, waiting for back ordered fan customer ran it off of a 12 V battery from the board, after a few hours unit started backup Tech manual not available at onset of repair, found later on this site Bosh manual & reset or cleared error code unit running a few days now on it's own. Error was a door switch code cust says.
Edited by kokomo
addenda
The ice maker removal is the same as the Daewoo FDBM.
