Manufacturer: Unknown
Type of Appliance: Fridge
Model Number: 106.77292790
106.77292790 Tech Sheet Please
Thank you!
This PUB number is already in the Downloads. Do you remember how to find it?
- go to the Sears site and enter the model number.
- find the tech sheet part number, copy and paste it into the Downloads search here at Appliantology (without the "LIT" prefix, just the number)
- you'll find the same PUB but used with a different model.
I'm not sure what you are asking.
Should I have done this prior to requesting this tech sheet?
In any case, I just went to Sears site and was not able to find tech sheet part number.
Not entirely sure why you are requesting that I go to Sears site.
Not being critical, I just don't understand.
Andy
I'm trying to help you help yourself so you can get the information quicker in the future.
Go ahead and follow my instructions and try it now.
  • Thanks 1
Andy,
  1. Go to Sears Parts Direct
  2. choose "search by model number."
  3. enter 106.77292790 into the search field.
  4. click on "cabinet parts."
  5. top right of the picture/parts diagram is a little booklet image marked "literature."
  6. Technical sheet       Parts #: LIT2195481
  7. The part # for the tech sheet is 2195481 ( drop the LIT pre-fix)
  8. take 2195481 and enter it in the Appliantology search bar, then hover on the left side of the search bar and choose to search in "files."
Samurai ascribes to the "...teach a man to fish" philosophy- I am in total agreement.
That is a great philosophy.
I am eager to learn.
I asked the question, "should I have done that before requesting through appliantology"
And if so, when do I do that instead of requesting through appliantology?
Thank you for all you do,
Andy
4 hours ago, Hiroshi said:
Andy,
This is one of the steps of trying to locate the tech sheet on Appliantology. If you do this step and then don't find it in the downloads then submit a request.
Are you going to other sites such as appliancepartspros.com and verifying your model. I just helped you on 2 other request where you said manufacturer was unknown, you also did that on this post. If you verify the model number then it will also tell you who the manufacturer is. More leg work you do the faster you find your info.
