Click here to take the quiz.
      6
something got hot enough to melt the top side of the plastic shroud around the magnetron fan.  The heat  changed the plastic fan shroud's shape so fan can not turn.  I have cut that away and fan can turn now.  The unit buzzes when the door is shut and there is current flow to magnetron and capacitor from transformer.
  • Replies 8
  • rvrose
    6
  • Chat_in_FL
  • johntech
If door is open, buzzing stops.  Door switch?
Likely the high voltage  relay on the control board.
Part number: WB27X11114
Thanks for the diagnosis, would this also cause a buzzing that seems much louder than normal operation?  by the way, I did check the door switches before I read this and they are all good.
plus, i see 12 relays stacked on the existing smart board and I see only 10 on the picture you included. My model number is PSA2200RWW 02  S/N VV300056K
my board has # EAX58990201
I did just verify that the bottom left relay is shorted, RY14 M.G.T. , so ...good job! ... and please verify the board for me.
Repair clinic and appliance parts pros list this board for you model.
Part number: WB27X11111
