Frigidaire Combo unit washer plus dryer (gcet1041as1) leaking water HELP PLEASE
Hi this is top washer/dryer combo that leaks water that leaks from the top and just behind and underneath according cus.
Does anyone have manual and help what could be ....
Service manual if anyone has appreciated. Does anyone knows how to disassemble stackable unit?
  • AccApp
  • johntech
  • Dj365
You would need to upgrade your membership. Grasshoppers do not have access to service manuals. To open the washer you remove the back slanted panel above the washer. The bolts that secure the lid are behind that cover. Remove bolts, slide lid forward and off. That will give you access to the screws that hold the front panel. Run the unit and hopefully you can see where it is leaking from.
You must be thinking of the Whirlpool company's fine offerings.
The Frigidaire laundry centers can have the washer compartment accessed by removing the two screws at the bottom of the front panel and shoving the front panel downward. The screws are installed very tightly and angle slightly downward. I use a piece of wood to prop the front up and a #2 Robertson screwdriver or bit to crack them loose, You will likely strip the heads out if you try to use a Phillips screwdriver or bit. Should be easy to find the leak with the cover off. I'd look first to the tub to pump hose, then the inlet assembly and worst case scenario would be the inner tub trunnion bolts sheared and allowed the inner tub to abrade a hole in the outer tub. A screw protruding through the inner tub can trepan a nice groove through the outer tub as well.
