replacement start relay Frigidaire GM-380E
My old Frigidaire GM-380E minifridge refuses to start - no clicking. Compressor checks out okay electrically - it's a Danfoss PW3.5K7. The old start relay does rattle noticeably when shaken which I'm led to believe indicates that it may be dead. The relay, overload protector and socket that plugs into the compressor are three separate pieces (wish I could post a picture). On the relay there is a sticker that says MAX IN 4.75 MIN OUT 3.75. It was manufactured by Danfoss and has 054-1279 stamped on it. Is there a modern replacement relay that will work? Any additional info required?
Thanks for any help.
  • Replies 8
  • Hiroshi
    4
  • granta
    4
  • electro_doc
Any PTC type relay will work... if it is not "clicking" it is possible the overload has quit as well. The easiest thing for you to do would be to install a PRO41.Part number: PRO41
Part number: PRO41
does the relay get power?
As a "Grasshoppah" I'm not exactly sure who this reply is going to! Thanks for the replies though.
Yes - the relay is getting power - thanks for suggesting that check. I started the compressor by wiring it directly and shorting the run/start pins so the compressor is, in fact, alive. The thermostat and overload check out okay. I'll go with Hiroshi's recommendation of the PTC relay. Thanks again.
Your replies are visible to all the visitors and Techs in the forum... Aftermarket parts are not always my first choice, but on the older units you have to use whatever will work!
Our local Supco distributor has an RO41 - no PRO41. what is the difference (apart from appearance) and is it compatible? Thanks.
it is a comparable RO ( relay/overload) the "P" stands for Push-On... the RO41 will require different wiring.
I would get a RCO410 if they have that, it will come with easy to follow instructions and a start capacitor to kick that aging start winding decisively into motion... If you can keep the old overload in the circuit, do so, you will treat the lead on the overload as the "common" on the RCO410 instructions...
Thanks Hiroshi - I'll try to track one down up here in the great white North. we
