New to me washer, all the bells and whistles.  Except it doesn't.  No chimes are evident- even at the end of the cycle.  I've pressed the "cycle signal" button.  No change.  Not a big deal but I would like to know when the washer is done.
Thank you gurus!
Susan K
  • Replies 6
  • skissman
  • Hiroshi
  • sh2sh2
Edit:  WFW96HEAU0
The vast majority of control boards out there have a small speaker mounted on the circuit board, ocassionally, the solder joint on the part gives way and the result is SILENCE.
www.youtube.com/watch?v=-G16BPb2PKw
It is really not worth the trouble for this one detail, considering the board costs 200 dollars- buy a 99 cent egg timer from the dollar store and crank it to 60 minutes before you walk away from the laundry...
I figured as much. :) Egg timer it is.   Maybe this one? Image result for timers
Very stylish!
Hold the cycle signal button for 5 seconds, see if that changes anything
And yes, reading the manual for the Tone adjustment instructions never hurts...!
