Maytag PAV2300AWW washer. When set to spin mode, nothing turns, but I can hear the timer clicking away. Lid switch seems to be fine. Motor and Drain pump turn freely. Clutch assembly turns until it locks up, then I can turn it the opposite way.
Do I need a new motor?
  • xman1x
  • Hiroshi
  • evaappliance
You have to answer one question before the decision can be made about the motor:
Is there 120VAC to the motor when you have spin selected?  The red wire at #4 position on the motor plug to the nearby ground should be 120VAC with spin selected, lid closed.
If there is no voltage to the motor circuit, it is the timer.
most of the time on these , if the motor is bad  it will be humming when you try it .
Yes, that is my thought as well. Thank you!
