Maytag Portable Dishwasher MDB465DAWB Fills & Won't Start
foxcitiesappliance
We are working on a Maytag Portable dishwasher and is filling with water, but won't continue on.. If you hit cancel it is only sending 10 volts to the drain pump. Cannot locate any tech data sheet for this model. Any thoughts? Thanks!
  • foxcitiesappliance
  • johntech
  • evaappliance
The model number has to be MDB4650awb
Press heated dry 5x followed by start button to start diagnostic cycle test. Test voltages to wash motor and drain pump at appropriate times during test. If you not receiving correct voltages then inspect wireing. If that is good the replace main control. I would test for voltages directly at he control to rule out the wire harness. You may even be able to see visible damage on back side of main control.
Part number: 12002713
foxcitiesappliance
MDC4650awb is the model number based on it being a portable dishwasher. Anyways, can i get a tech data sheet please to help me understand the codes and such in the test mode. Thx!
You will have to sign up as a professional appliantolagist to download tech sheets
