Manufacturer: GE
Type of Appliance: dishwasher
Model Number: GLD5760N10SS
Have a food-left-on-dishes complaint on this unit. Nothing in sump. Customer using detergent pods and rinse-aid. Water valve replaced by previous servicer. Fills cup in upper rack in 45 seconds. Heater comes on during test cycle at appropriate wattage.
NTC measures 46K at room temperature but minimanual gives no value range. Trying to figure out if heater may not be coming on during cycle.
  • DanInKansas
  • Chat_in_FL
  • Lighthouse
it uses this mini manual
This technical service guide may help you out
Yeah, unfortunately the full manual takes me to a unit that uses a turbidity sensor, which this model doesn't use. The minimanual doesn't have resistance ranges. So there's no way for me to know if that sensor is right. It's probably just fine but I'm at a loss.
On 9/5/2017 at 11:32 PM, DanInKansas said:
Manufacturer: GE
I'm leaning towards over-sudsing, don't dismiss this to quickly. Load and watch...
Guest
This topic is now closed to further replies.
