kfis25xvms2 refrigerator intermittent issue
Hi everyone...   I have the above Kitchenaid fridge/freezer.  For about 6 weeks now there has been an annoying issue.  The unit is getting power, but occasionally stops working, and the display blanks.  No controls work.   After a while you can hear the unit trying to start, with the compressor starting for a few seconds then giving up.  Then out of the blue, it starts up and works perfectly for a few days.
I had a spare control unit (the part mounted on the front of the door) which didn't help.  I have installed a new capacitor, and starter unit on the compressor, again to no effect.
Any ideas?
Mike
  • Replies 7
  • Biggboy
    5
  • 16345Ed
  • KaveMan
Nobody....   not one suggestion   <<sigh>>
Oh well I guess it was worth a try
Intermittent problems are the toughest to diagnose. The compressor is powered off the Main Control Board in the rear of the fridge, not the dispenser control board you replaced. I would start back there, check for loose connections and if the board has obvious damage, like a burnt spot. Also make sure the outlet you plug the fridge into is good, properly grounded and doesn't have a loose neutral. Board part number is WPW10310240.
  • 3 weeks later...
OK, that was great, and fixed the problem, in 10 minutes tops...  The only issue was the programming, it came with instructions for a Maytag, not a Kitchenaid...
You replaced main control board?
17 hours ago, Biggboy said:
Yes, very easy to do...
